MMOexp ARC Raiders to skip most of the climb
Arc Raiders' Combat Recon quest is a pivotal mid-game mission that blends exploration, stealth, and strategic combat. Given by Shani-Speranza's head of security-this quest tasks you with scouting critical locations in the Buried City and neutralizing Arc spotters, all while gathering vital intelligence to ARC Raiders BluePrints  counter the mechanical menace.
Designed to test your navigation skills and combat awareness, Combat Recon is more than just a fetch quest: it teaches core mechanics like cover usage, enemy prioritization, and loot extraction. Whether you're a solo raider or playing with a squad, this guide will walk you through every step efficiently, ensuring you complete the quest without unnecessary setbacks.
1. Quest Prerequisites & Preparation
Before diving into Combat Recon, you need to meet a few simple prerequisites. First, you must have completed Shani's earlier quests, such as "Picking Up the Pieces" and "Clearer Skies," as quest chains in Arc Raiders are linear-new missions unlock only after finishing previous ones.
Next, prepare your loadout for success. This quest requires both recon and combat, so prioritize versatility. Equip a reliable assault rifle (like the Rattler III) for medium-range fights and a heavy weapon (such as the Ferro IV) to take down spotters quickly.
Don't forget utility items: a zipline to traverse rooftops, a healing spray (Vita Spray) for emergencies, and a tagging grenade to reveal hidden enemies. These tools will save you time and keep you alive in the contested Buried City.
Finally, ensure you have enough ammo (especially heavy ammo for spotters) and a free inventory slot-you'll need to collect a Spotter Relay later in the quest to turn in to Shani.
2. Step 1: Scope Out the Parking Garage Stairwell
Your first objective is to scout a cover position inside the Buried City's parking garage stairwell. The parking garage is easy to locate: it sits near the hospital and space travel buildings, making it a distinct POI on your map.
Once you reach the garage, avoid unnecessary fights with patrolling Arc drones. Head inside and climb the staircases until you reach the garage exit door. For a faster route, use the zipline in the center of the garage to skip most of the climb.
When you reach the designated cover spot near the exit door, a yellow interaction prompt will appear. Press "E" to scope out the area-this completes the first objective. Move quickly afterward, as Arc patrols often wander into the stairwell.
3. Step 2: Scope Out the Buses Near Marano Park
Next, make your way to Marano Park, located near the center of the Buried City map. This area is often patrolled by Bombardiers and their accompanying spotters, so stay alert and use cover to avoid detection.
The objective is to scope out a cover spot near the buses parked at the western entrance of the park. These buses are broken and scattered, providing natural cover from enemy fire.
Approach the bus closest to the nearby building, circle to the left, and look for the yellow interaction prompt. Press "E" to scout the area-this marks the second objective as complete. Take a moment to ARCR Items for sale  check your surroundings; Bombardiers often spawn nearby, so be ready to fight or flee.
  MMOexp Diablo4 chances with simple strategies BennieDe 0 24 Vor 9 Stunden
Letzter Beitrag: BennieDe
