Olympischer 8''-Kampf?
#61
Zitat:Was haltet ihr vom Emi Beta 8A ?
Den 8A kenne ich nicht, ich habe aber gute Erfahrungen mit dem Beta-8CX (Koax) in meinen Brüllwürfeln gemacht. Läuft bei mir in 30 Liter BR bis 50Hz runter und ist für einen 20er ordentlich pegelfest. Auch der Mittelton überzeugt. Ich denke, der Beta-8A ist da ähnlich.
Olli
Aus den FAQs von B&C:
Zitat:How does B&C calculate the Xmax (excursion) specification, and what is Xvar?
- Evolution is a process that affects not only products, but also their technical specifications. Constant advances in research provide more and more precise methods to measure the performance of loudspeakers, and describe their features. Thiele – Small parameters have become the universal language for describing loudspeaker behaviour in the small signal domain. Nevertheless, they comment little on the working limits of loudspeakers in the large signal regime. These limits are customarily indicated by Xmax, the maximum linear excursion. This value, measured in our catalogue according to AES2-1984 standard, corresponds to a maximum of 10% total harmonic distortion (THD) with a sinusoidal signal. Recent research shows that this method can yield ambiguous results, and even different numerical values for the same loudspeaker. The main limit of this measurement is that it looks at the output signal instead of the physical features of the driver itself. On the contrary, the most up-to-date instruments for distortion analysis can measure the variations in loudspeaker parameters when they are fed with high-level signals. In this way, an excursion limit can be fixed, beyond which the parameter’s variation becomes excessive. The “Xvar” value reported in our data (generally after the traditional “Xmax” value) is measured this way. Beyond this excursion limit, the magnetic field seen by the voice coil, or the total suspension compliance, or both, drops to less than 50% of their small signal value, producing high distortion levels, strong variations from small signal behaviour and power compression. The new technique yields different results from the standard measurement based on THD.
Michael schrieb:Ich bin einfach mal von Dolby Digital / DTS ausgegangen, somit sind die 80Hz Trennfrequenz SAT/SUB vorgegeben.
Netter Rettungsversuch, er hat aber eine ganz andere Anforderung schon im ersten Post gestellt. Man kann sich jetzt also aussuchen, ob Du einfach auf seine Kriterien schei**t oder das jetzt eine billige Ausrede ist. Rolleyes
hesinde2006 schrieb:Na dann bau ich halt ein wenig grösser und falte den KanalCool
Naja, man sollte mit realistischen Werten simulieren. Nachdem Du ja auch den Mittelton nutzen möchtest, sollte der Port gut überlegt sein, wegen dem Mitteltonmüll, der aus dem Rohr kommt. Dazu gibt's auch bei so großen Rohren große Probleme mit Längsresonanzen.
Dosenfutter schrieb:Netter Rettungsversuch, er hat aber eine ganz andere Anforderung schon im ersten Post gestellt. Man kann sich jetzt also aussuchen, ob Du einfach auf seine Kriterien schei**t oder das jetzt eine billige Ausrede ist. Rolleyes
Mensch Leute, muß das sein? Man muß sich doch nicht gleich in die Kletten kriegen. Immer locker Wink :thumbup:
Olli
Was ist an der Anforderung Heimkino falsch zuverstehen?
Ein 5.1 AV-Verstärker trennt halt nunmal bei 80hz.
Gruß Michael
hoschibill schrieb:Mensch Leute, muß das sein? Man muß sich doch nicht gleich in die Kletten kriegen. Immer locker Wink :thumbup:
Ja, Du hast ja recht..
Dosenfutter schrieb:Ja, Du hast ja recht..
Und wer Recht hat, gibt einen aus? Geht klar, wenn Du Ostersamstag auch in Duisburg bei K+T bist Wink Big Grin :prost:
Olli
Zitat: Ein 5.1 AV-Verstärker trennt halt nunmal bei 80hz.
Bei den meisten modernen Verstärker ist die TF einstellbar.
hoschibill schrieb:Und wer Recht hat, gibt einen aus? Geht klar, wenn Du Ostersamstag auch in Duisburg bei K+T bist Wink Big Grin :prost:
Hehe, würde ich gerne, aber ich hab leider keine (Mit-)Fahrgelegenheit. Sad
Dosenfutter schrieb:Hehe, würde ich gerne, aber ich hab leider keine (Mit-)Fahrgelegenheit. Sad
Wo kommst Du denn her?
Leute!!Ihr seid sowas von Offtopic
Ich habe mich vorerst für die Monacor SP-8/150PA plus DT99 im Waveguide entschieden.
hesinde2006 schrieb:Leute!!Ihr seid sowas von Offtopic
Meinst Du nicht, daß die paar Zeilen OT verzeilich sind, nachdem ich hier so viel konstruktiv beigetragen habe?
hesinde2006 schrieb:Ich habe mich vorerst für die Monacor SP-8/150PA plus DT99 im Waveguide entschieden.
Prima. Für die WG ist der DT 300 allerdings besser geeignet.
Zitat: Meinst Du nicht, daß die paar Zeilen OT verzeilich sind, nachdem ich hier so viel konstruktiv beigetragen habe?
Klar, sollte auch nur ein Hinweis sein.
Zitat:Für die WG ist der DT 300 allerdings besser geeignet.
Der DT 300 ist vermutlich belastbarer und ich muss nicht am WG rumfräsen.
hesinde2006 schrieb:Der DT 300 ist vermutlich belastbarer und ich muss nicht am WG rumfräsen.
So ist es. Wink
  Olympischer 10''-Kampf? Chlang 59 34.420 12.07.2010, 13:11
Letzter Beitrag: Chlang
