Does this Arta voltage probe look correct?
Here is the Arta Voltage probe I made today.
I think I wired it correctly and used all the correct value parts.
​I am still not 100% if I picked the correct parts as there are so many options beyond what the Arta voltage probe diagram mentions.
Diode I used,
PART: BZX55C4V3-TAPGICT-ND
MFG : Vishay Semiconductor Diodes Division (VA) / BZX55C4V3-TAP
DESC: DIODE ZENER 4.3V 500MW DO35
https://www.digikey.ca/en/products/detai...EThAF0BfIA
920 Ohm resistor I used,
PART: A129366-ND
MFG : TE Connectivity Passive Product / H4P910RFZA
DESC: RES 910 OHM 1W 1% AXIAL
https://www.digikey.ca/en/products/detai...gERAF0BfIA
8.2K Ohm resistor I used,
PART: A129365-ND
MFG : TE Connectivity Passive Product / H4P8K2FZA
DESC: RES 8.2K OHM 1W 1% AXIAL
https://www.digikey.ca/en/products/detai...QIIgF0BfIA
Does it look okay?
Hi Dave,
i cannot check the wiring of your box by photo only, but the parts and the diagram are corect.
best regards and good luck
  ARTA Turntable MK II ente 20 33.646 15.10.2025, 07:46
Letzter Beitrag: Hank
  ARTA wird Freeware ente 8 5.456 09.12.2024, 20:17
Letzter Beitrag: Malik
  ARTA Ringversuch #3 stoneeh 35 49.156 09.05.2024, 19:39
Letzter Beitrag: stoneeh
  ARTA mit Turntable ente 181 187.108 06.05.2024, 10:19
Letzter Beitrag: DemonCleaner
  ARTA, Einstellung der Produktpflege ente 10 10.776 30.03.2024, 11:18
  Ende der Arta Entwicklung? Micha_HK 8 7.933 09.03.2024, 10:57
  Arta 1.9.7 ente 0 14.705 05.12.2023, 08:05
Letzter Beitrag: ente
  ARTA MessBox 4.1 ente 12 19.891 16.11.2023, 15:53
  Arta 1.9.6 ente 1 6.662 02.02.2023, 20:29
Letzter Beitrag: ansch
  Arta 1.9.4 ente 9 10.562 02.11.2022, 10:00
Letzter Beitrag: Don Key
