Camilladsp 2.0.0
Henrik hat eine 2.0.0 Alpha-Version von Camilladsp veröffentlicht.
Zitat aus dem diyAudio-Forum:
Zitat:The first preview of v2.0 is up, get it at https://github.com/HEnquist/camilladsp/r...0.0-alpha1
Previews of the gui and supporting python libraries are nearly ready and will be published soon.
Changes from v1.0.3:
New features:
  • Add dynamic range compressor.
  • Add websocket commands to read peak and rms history.
  • Add ToggleMute websocket command.
  • Add AdjustVolume websocket command for relative volume changes.
  • Better handling of USB gadget in Alsa backend.
  • Add option to bypass pipeline steps.
  • Bluetooth capture support on Linux via Bluez.
  • Updated resampler with faster lower quality options.
  • Higher precision of biquad filters.
  • More flexible configuration of resampler type and quality.
  • Allow setting optional config parameters to null to use default value.
  • Add "Dummy" convolution filter type for easier CPU load testing.
  • Add title and description fields to various parts of the config.
  • Gain can be specified in dB or linear scale.
  • Websocket command to reset clipped samples counter.
  • Add an always enabled default volume control.
  • Add several volume control channels (faders).
  • Change Loudness filter to only perform loudness compensation.
  • Add more ditherers.
  • Add GeneralNotch biquad type.
  • Add Tilt equalizer biquad combo.
  • Add GraphicEqualizer biquad combo.
  • Support rate adjust for BlachHole on macOS.
  • Add statefile for persisting runtime parameters to file.
  • Websocket command to get pipeline processing capacity utilization.
  • Add commands to read statefile path and updating status.
  • Improved handling of config changes via SIGHUP and websocket.
Changes:
  • Optimize cpu load in general, and of dithering and delay filters in particular.
  • More logical names for dither types.
  • Updated Shibata dither coeffients.
  • Rename Set/GetConfigName websocket commands to Set/GetConfigFilePath.
  • Removed redundant`change_format` parameter to simplify CoreAudio device config.
Gibt es hier im Forum bereits Nutzer der bisherigen CDSP-Version?
Bei mir im Heimkino läuft das bisher vorzüglich auf einem alten i5-Barebone zusammen mit UMC1820+ADA8200.
danke für den Hinweis!
Wollte ich gleich mal spontan ausprobieren.
Nachdem ich alle 'mögliche-Bedrohung'-Warnungen weggeklickt habe, startet die Anwendung trotzdem bei mir nicht (auch nicht als Admin).
Muss ich noch irgendwas beachten ?
Hi Matthias,
bin selbst nach diesem Howto bei der Installation unter Linux vorgegangen:
https://www.audiosciencereview.com/forum...ial.29656/
Die ist zwar für den RPI, funktioniert aber auch auf einem PC oder Barebone.
Unter Windows oder anderen möglichen Betriebssystemen habe ich es nicht probiert.
Edit:
Wie die Web-GUI dazu ausschaut sieht man in dem Post hier ganz gut:
https://www.audiosciencereview.com/forum...st-1038294
Bei mit läuft CamillaDSP seit Jahren super stabil unter Ubuntu in Verbindung mit Alsa und Kodi als sechs Kanal Frequenzweiche und Raumanpassung mit mixed FIR/IIR; was einer der Unterschiede ist zu anderer Software wie z. B. BruteFIR.
Hatte mit dem Entwickler auch schon mal Kontakt über ein anderes Forum; super hilfsbereit und einfach Toll, was er da leistet!
Zitat:super stabil unter Ubuntu in Verbindung mit Alsa
Dito bei mir auch seit ein paar Monaten mit FIR/IIR auf 12 In und 20 Out Kanälen.
Finde ich auch. Falls er hierdrüber stolpert ein großes Dankeschön auch von mir.
Henrik hat heute offiziell die 2.0.0 released:
https://github.com/HEnquist/camilladsp/releases
mdsimon2 war so freundlich und hat sein Installations-Tutorial für die Version 2.0.0 erweitert:
Hier ein Screenshot daraus:
[ATTACH=CONFIG]72830[/ATTACH]
VG und Frohe Weihnachten
Das Tutorial ist für Ubuntu auf RPI4. Was ist anders auf PC (Win oder Ubuntu)?
capslock schrieb:Das Tutorial ist für Ubuntu auf RPI4. Was ist anders auf PC (Win oder Ubuntu)?
so gut wie nichts. Betreibe es aktuell auf einem alten Quadcore i5 unter Ubuntu 20.04.6 LTS und da müssen nur diese Zeilen geändert werden:
[ATTACH=CONFIG]72832[/ATTACH]
von
camilladsp-linux-aarch64.tar.gz
in
camilladsp-linux-amd64.tar.gz
Edit:
So was z.B. für 116,50€ reicht völlig für 20 FIR-Ausgabekanäle mit riesiger Taps Anzahl.
https://www.refurbed.de/p/lenovo-thinkce...910q-tiny/
auch wenn es hier anscheinend keinen interessiert…
Ubuntu 22.04.3 macht auf nem anderen Rechner Zicken mit der externen USB Soundkarte. Alsa sieht keine Karte und die üblichen Linux-Foren schreiben was von Kernelbug.
Bin wieder zurück auf 20.04.6, denn damit tut es.
ich hab noch mal die Windows-Installation probiert.
Komme aber nicht weiter als vor ein paar Monaten.
Gibt es auch Tutorial für Windows?
Danke und Grüße
edit:
ok, hab gerade bei asr etwas nachgelesen.
CamillaDSP scheint also gar nicht direkt über windows zu laufen, sonder nur via powershell?
mhh, sowas ist mir leider inzwischen zu kompliziert.
Schade, das Bedienkonzept und die Funktionalität von CamillaDSP sieht echt sehr gut aus.
Habe mir zwar gerade einen RPi 4 geordert, bin da aber totaler Noob. Windows würde mich daher auch sehr interessieren, zumal ich den einen oder anderen alten Laptop mit Touchscreen rumstehen habe, die kaum mehr als ein RPi verbrauchen.
Micha_HK schrieb:Hallo,
Mich schon, auch wenn ich nur still mitlese Smile
Micha_HK schrieb:Bin wieder zurück auf 20.04.6, denn damit tut es.
Damit tut hier leider nur V1. Zu früh gefreut, die fertige Linux Binary vom Henrik braucht folgende Glibc und auf 20.04 ist nur eine ältere…Sad
Zitat:camilladsp: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by camilladsp)
camilladsp: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.32' not found (required by camilladsp)
camilladsp: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by camilladsp)
Schade, muss wohl doch selber bauen.
Installation unter Windows oder MacOS habe ich nicht probiert und auch nicht vor, da schon genug Baustellen hier. :prost:
Edit:
Selber bauen ging nach Henriks Beschreibung eigentlich problemlos und jetzt gibt es diesen Glibc Fehler nicht mehr, aber leider spinnt Alsa immer noch, obwohl alsamixer die USB-Soundkarte sieht…
so, geht doch auch unter Ubuntu 22.04.3
Nachdem ich mir die 20.04 zerschossen habe beim Auflösen der Abhängigkeiten… habe ich nochmal 22.04.3 neu aufgesetzt und getestet. Mit sudo lief camilladsp.
Rätsels Lösung: Camilladsp als "non root" muss der "user" noch manuell in die audio Gruppe
:p
Eventuell lag es auch daran, dass ich im Bios den onboard Sound disabled habe und jetzt wieder enabled… Denn die root-Geschichte hatte ich anfangs eigentlich gecheckt. Rolleyes
Darakon schrieb:ich hab noch mal die Windows-Installation probiert.
Woran hängt es denn gerade? Vielleicht kann man dir ja weiterhelfen.
Darakon schrieb:CamillaDSP scheint also gar nicht direkt über windows zu laufen, sonder nur via powershell?
Ich würde vermuten, dass der User eher Linux- als Windowsaffin ist und deswegen den Weg gewählt hat.
Prinzipiell sehe ich keinen Grund, warum es nicht direkt unter Windows laufen sollte. Es wird ein Windows-Binary zum Download angeben und es gibt eine offizielle WASAPI-Doku.
hier hat jemand kurz den Weg der Windows Installation beschrieben:
https://hifive.sg/index.php?threads/cami...post-32458
Allerdings nichts zu den Versionsdetails der nötigen (Python)Pakete…
Für Leute mit weniger Erfahrungen mit solchen Sachen wäre eine fertige Distribution eventuell besser geeignet. Z.B:
https://moodeaudio.org/
Also der Thread zur Windowsinstallation ist etwas zu top level, um nützlich zu sein. Bei den meisten Schritten fehlen 1-2 Sätze, was man konkret machen soll.
Moode ist sicher interessant, wenn auch auf RPi beschränkt. Vor allem ist sympathisch, dass es ein gutes WEB-gui gibt. Was ich noch nicht gefunden habe: wo gibt es ein Changelog oder eine Info, welche Version von Camilla eingebunden ist?
Camilla Version: 1.0.3
bei der Latest release 8.3.7
Bernd
  Kleiner Guide: CamillaDSP plus Audio Injector Octo 6x8 Interface an Raspberry Pi 4 Malik 13 87.676 06.09.2025, 11:04
Letzter Beitrag: Malik
