Suche diese spezielle Schaltung
Ich hab es ausprobiert. Es muss ein Raster sein kein Taster.
Somit bleibt das ursprüngliche Problem bestehen.
Die Lösung mit dem Relais ist dann wahrscheinlich die naheliegendste.
Doch Big Grin .....ich habe mal ChatGPT Gefragt .... der kam direkt mit einem Schaltplan mit Logic Bausteinen .... Der Schaltpaln wird aber unleserlich, wenn man ihr hier rein kopiert. Kriegst Du bestimmt selber hin, wenn Du in die Richtung willst.
[FONT=Söhne]To create a bistable logic circuit with just one switch (taster) that toggles between two states, we can use a D flip-flop. Here's a schematic using a D flip-flop:[/FONT]
[COLOR=var(--text-secondary)][FONT=Söhne]lua
Copy code[/FONT][/COLOR]
+[COLOR=rgba(255, 255, 255, 0.5)]-------------------------------------+[/COLOR]
+[COLOR=rgba(255, 255, 255, 0.5)]-----|------+ +----|-----+[/COLOR]
| | | +[COLOR=rgba(255, 255, 255, 0.5)]----------------+ | | |[/COLOR]
| | +[COLOR=rgba(255, 255, 255, 0.5)]----| D Flip-Flop |---+ | |[/COLOR]
| | +[COLOR=rgba(255, 255, 255, 0.5)]------| Q |<-------+ |[/COLOR]
| | | +[COLOR=rgba(255, 255, 255, 0.5)]----------------+ |[/COLOR]
| | +[COLOR=rgba(255, 255, 255, 0.5)]------| Q' |-------------+[/COLOR]
| | +[COLOR=rgba(255, 255, 255, 0.5)]----------------+[/COLOR]
+[COLOR=rgba(255, 255, 255, 0.5)]-----+[/COLOR]
[FONT=Söhne]In this schematic:[/FONT]
  • D is the data input.
  • Q is the output.
  • Q' is the complement of the output.
[FONT=Söhne]Here's how it works:[/FONT]
  1. Initially, both Q and Q' are at a known state, typically 0.
  2. When you press the switch (taster), it toggles the input D.
  3. The flip-flop's output Q will change to match the input D on the rising edge of the clock signal (which we assume to be present). If D is high, Q becomes high; if D is low, Q becomes low.
  4. Q' will be the complement of Q, representing the opposite state.
[FONT=Söhne]This way, with just one switch, you can toggle between the two states represented by the output Q.[/FONT]
  Suche Desktop-Amp mit DSP und 4 oder 5 Kanälen impact 57 25.000 17.05.2025, 07:29
  Suche Unterstützung einfachste PIC Controllerprogrammierung für Tmag-805 (AUDIY) SNT 2 4.075 08.07.2024, 18:05
Letzter Beitrag: SNT
  Suche Streamer ... wus 13 9.540 18.04.2024, 06:19
  Suche Streamer wie Auralic Altair G1 aber Steuerung ohne Apple-Device krama1974 11 5.765 26.09.2023, 12:07
  Wo bekomme ich diese Kondensatoren?? misux 11 4.187 20.09.2023, 11:58
Letzter Beitrag: misux
  suche USB Soundkarte digital out dy1026u 28 8.970 16.05.2023, 21:34
Letzter Beitrag: dipoluser
  suche USB-SoundInterface für Lautsprecher u. Verstärkermessungen Udo 18 7.755 09.05.2023, 19:20
Letzter Beitrag: Udo
  Suche kleinen Verstärker mit Bluetooth und Monoschalter wolf-sascha 5 2.804 26.01.2023, 17:41
Letzter Beitrag: wolf-sascha
  Suche DAC mit Streamer preiswert für Zweitanlage dws37 7 2.695 07.01.2023, 20:36
Letzter Beitrag: dws37
  Suche Raspberry Pi CM 4 für Sohnemann zum Christkind kboe 20 7.164 15.12.2022, 19:27
Letzter Beitrag: Roul
