Raspberry PI / KODI / aktiv Weiche (BruteFIR?)
Versuch mal weniger Taps.
So etwas ähnliches hatte ich auch. Könnte mir vorstellen das da irgendwas nicht mitkommt.
Habe ich gerade auch versucht.
Aber leider ohne Erfolg.
Manchmal läuft es für ca 30 sec manchmal garnicht.Confused
Aktueller Stand : (als root gestartet)
Code:
faltpc-desktop faltpc # brutefir -nodefault /home/faltpc/.brute48_config BruteFIR v1.0l (October 2013) (c) Anders Torger Internal resolution is 32 bit floating point. SSE capability detected -- optimisation enabled. Creating 4 FFTW plans of size 65536...finished. Warning: could not save wisdom: could not open "home/faltpc/.brutefir_convolver" for writing: No such file or directory. Loading 4 coefficient sets...finished. Realtime priorities are min = 2, usermax = 1, mid = 3 and max = 4. Estimated CPU clock rate is 1999.999 MHz. CPU count is 4. Filters in process 0: 0 Filters in process 1: 1 Filters in process 2: 2 Filters in process 3: 3 Input poll mode activated Realtime priority 3 set for input process (pid 27375) Realtime priority 4 set for filter process (pid 27474) Realtime priority 4 set for filter process (pid 27473) Realtime priority 4 set for filter process (pid 27475) Realtime priority 4 set for filter process (pid 27472) Realtime priority 3 set for output process (pid 27476) Fixed I/O-delay is 65536 samples Audio processing starts now ALSA I/O: underflow! (write on p??) ALSA I/O: underflow! (write on p??) ALSA I/O: underflow! (write on p??) rti: 0.025 peak: 0/0/+nan 1/0/+nan 2/0/+nan 3/0/+nan ALSA I/O: underflow! (write on p??) rti: 0.023 ALSA I/O: underflow! (write on p??) ALSA I/O: underflow! (write on p??) rti: 0.024 peak: 0/0/+nan 1/0/+nan 2/0/+nan 3/0/+nan ALSA I/O: underflow! (write on p??) rti: 0.027 ALSA I/O: underflow! (write on p??) ALSA I/O: overflow! (read on ?V?) ALSA I/O: Could not restart audio: Broken pipe. I/O module failed to read, aborting.
Harry
Ich hatte das selbe Problem. Kann leider nicht mehr sagen was es dann genau war.
Evtl könntest du am Ausgang noch S16_LE versuchen
Eventuell auch das Ausgabedevice Namentlich benennen ohne Zahl.
Hoffe du weißt was ich mein
@Blaubeere
das hat nichts gebracht.Ich habe jetzt mal nur aus Spass
meine Gigaport HD+ mit drann gehängt.
Der Eingang kommt über die Maudio und der Ausgang geht an die Gigaport.und..... das läuft ohne zu murren.Cool
Harry
Kleines Update :
ES LEBT !!!!!!
Ich habe mal einfach so ein paar Kleinigkeiten abgeschaltet, was das Thema Energy sparen beim Prozessor im Bios betrifft und nur läuft die Kiste ne halbe Stunde ohne zu meckern. Ab und zu hab ich mal ein paar Peaks drinn, aber das können auch noch falsche Lautstärke einstellungen sein.
Na hoffen wir mal das es so bleibt.
Harry
  Kleiner Guide: CamillaDSP plus Audio Injector Octo 6x8 Interface an Raspberry Pi 4 Malik 13 87.833 06.09.2025, 11:04
Letzter Beitrag: Malik
  Einschaltstrom? stört raspberry baraku 17 5.392 11.10.2024, 22:04
Letzter Beitrag: baraku
  Streamer mit DSP auf Raspberry Basis kaufen oder selber bauen.... kboe 12 12.180 10.05.2024, 19:40
Letzter Beitrag: dipoluser
  Suche Raspberry Pi CM 4 für Sohnemann zum Christkind kboe 20 7.269 15.12.2022, 19:27
Letzter Beitrag: Roul
  digitale Weiche und DSP mit digitalen Ausgängen? dy1026u 51 21.186 27.07.2022, 21:32
Letzter Beitrag: dy1026u
  Raspberry - hier Multiroom ArLo62 2 1.762 26.07.2022, 18:47
Letzter Beitrag: ArLo62
  Spotify über Raspberry USB - wie? kboe 36 10.424 12.11.2021, 20:44
Letzter Beitrag: kboe
  Raspberry -> HDMI -> AVR 6-8Kanal Stereo Aktivbetrieb ? Udo 16 7.559 10.09.2020, 20:15
Letzter Beitrag: Udo
  Aktiv-Röhre? Koaxfan 51 12.755 20.06.2020, 12:18
Letzter Beitrag: D3a
  Raspberry Pi Mediaserver: Audio über I2S, Video über HDMI....? Ka-Bass 6 4.205 05.06.2020, 08:48
Letzter Beitrag: Ka-Bass
